Write Analysis to Get API call From the weather app and display the information on a widget
Hello! I am having a hard time writing the code for the analysis in extracting the API information from the weather app. I know I will need to store the data in the bucket, and have the API Key for the weather data, but knowing the parameters of which type of SDK I would need is confusing.
Did you have any solution?
I did exactly this on a customer.
My analysis look like this:
const { Analysis, Device, Utils } = require('@tago-io/sdk'); const axios = require('axios');  async function ImportDayForecast(context) {   const envVars = Utils.envToJson(context.environment);   if (!envVars.device_token) return context.log('Missing device_token environment variable');   const device = new Device({ token: envVars.device_token });    const options = {     url: 'Put your API URL here',     method: 'GET',   };    try {     const result = await axios(options);     // Some validations, this need to be done by you     if (!result.data.hasOwnProperty('data')) return console.log(`No property "data" in API response.`);     if (result.data.data.length === 0) return console.log(`Property "data" empty in API response.`);      // This code below delete old data, because I dont want save history, if you want to save history, dont use this code     await device.deleteData({       variable: 'day_forecast',       qty: 10000,     });      // Here I customize the response to my application     // I omit some irrelevant code in [...]     const forecasts = result.data.data.reverse().map((item) => {       const forecast = item;       [...]       return forecast;     });      let count = 0;      // Here I save new data.     // I using metadata to save some Data storage, if you dont use this technique, just save in normal way     // I omit some irrelevant code  [...]     for await (const forecast of forecasts) {       try {         await device.sendData({           variable: 'day_forecast',           value: '',           metadata: {             temperature: `Min: ${forecast.temperature.min}°C - Max: ${forecast.temperature.max}°C`,             humidity: `Min: ${forecast.humidity.min}% - Max: ${forecast.humidity.max}%`,             [...]           },         });         count += 1;       } catch (error) {         context.log(`Error when inserting: (${forecast.date_br})`, error);       }     }      context.log(`Successfully Inserted ${count} rows.`);   } catch (error) {     return context.log(`Error: ${error}`);   } }  module.exports = new Analysis(ImportDayForecast);
I comment the file to explain.
With the data saved in a bucket, you can do anything in dashboards.
Hope this help you.
