Hello everybody!
I’d like to know if there’s a way to put some visual information on my infoboxes within my Map widget. Is this possible or would i have to create a custom map widget from scratch in order to implement this feature?
Hello everybody!
Hi Renato,
You can add lots of information inside an infobox natively by utilizing multiple variables with the same group,
its also possible to add an image to an infobox or links to multiple images.
What are you trying to achieve?
It’s not quite that that i’m aiming at… i’d like to show actual widgets, like an up to date battery gauge or graph for example. It would be a way to condensate all my device’s relevant information just using the map and the infobox.
Ah I see now, yeah I believe you’d have to create a custom widget in order to show a another widget within the Map widget’s infobox.
Alright! Thanks for the help Freddy!
