Want to add a new Device, need Connector
hello everyone,
is it possible to add the following device?
Origolec ED20W
Attached you will find the payload documentation
Thank you!
I can’t attache the file. if you provide me the mail, i’ll send it.
Thanks,
Igor
Hi Igor,
It is really straight forward to create your own connector. Just click on the down arrow to the right of your profile icon, select Integrations and then Add Connector. Give it a name, select the network(s) and paste your payload parser.
The additional benefit is that you can tweak the payload parser to limit the number of variables as needed and change variable names as desired.
Erwin
