Use TagoIO files for custom dashboard backgrounds and logos [Tip #17 Carolina from Support]
Hi y’all, Carolina from support here :grinning_face:
Did you know you can use TagoIO files for logos, floor plans, and backgrounds in Image Widgets?
Yes! You can host your company assets directly in TagoIO and plug them into your Image Widgets! Here we go:
  1. Upload assets to Files: In the Admin, go to files and upload your images.
  2. Set access to Public: After uploading, set the file’s permission to Public so the URL can be used by dashboards and external viewers.
  3. Use the file URL in Image Widgets: Copy the public URL from Files and paste it into your Image Widget configuration so the image renders on your dashboard.
Another quick tip: you can also host custom widget assets the same way if needed.
