Trigger update on device parameter change
Greetings,
On our Blueprint Dashboard, a user can change a device parameter via the Device List widget. We use device parameters in combination with variables to visualize device and system info.
Is there a mechanism to automatically trigger an update (e.g. start an analysis) when one or more device parameters are changed? Actions allow you to trigger based on variable updates but not with parameters. Perhaps there is another way?
Hi zsu[@user:10052104078]zsu,
Thank you for reaching out!
Currently, TagoIO Actions do not support being triggered directly by configuration parameters. However, if you are using the Dynamic Table widget to modify device parameters, there is a built-in option to trigger an Analysis automatically whenever a value is edited.
If you’d like, I can guide you step-by-step on how to enable this feature in the Dynamic Table widget.
Please let me know if you’d like further assistance or have any other questions!
zsu[@user:10061942044]zsu thanks for this pointer, I had overlooked it. That should do the trick!
