Hi, is it possible to use dictionaries for translating text in a custom widget.
We obviously tried something like:
button.innerHTML = '#CWDGT.BUTTON_TEXT#';
but that didn’t work.
Any guidance would be highly appreciated.
Thanks,
Vincent
Thanks,
Vincent
Hi Vincent,
You’ll need to import the TagoIO SDK in order to be able to utilize your dictionary.
Hi Freddy, can you please provide more details?
How do I import an SDK into a custom widget code, this is what I have:
<script type="text/javascript" src="https://admin.tago.io/dist/custom-widget.min.js"></script>
Is that what you mean and if so, what coding is required for the translation.
Hi Vincent,
Heres an example using the dictionary in a custom widget, make sure to install the SDK via NPM:
useEffect(() => {
window.TagoIO.onSyncUserInformation((user) => {
if (user && !userSettings) {
setUserSettings(user);
}, [userSettings]);
useEffect(() => {
const loadDictionary = async () => {
if (userSettings && apiURL && sseURL) {
const { language, token, runURL } = userSettings;
const dictionary = await new Dictionary({
token,
language,
runURL: runURL || "",
region: {
api: "apiURL.com",
sse: "sseURL.com",
const translation = dictionary.applyToString("#EXAMPLE.EXAMPLE#");
loadDictionary();
}, [userSettings]);
Hi Freddy,
Thanks for sharing the example.
I’m a bit confused and could use some clarification. Specifically:
Right now, I’m only creating the HTML files without a build pipeline, so I feel like I might be missing some fundamental steps to get this working.
Appreciate your guidance on this.
Best,
Vincent
Hi Vincent,
Our SDK is designed to work in environments that support module bundling (such as Webpack, Vite, or similar) or in Node.js. It is not possible to use it directly in a plain HTML file with a tag, because the SDK uses modern JavaScript modules and dependencies that require a build step to run in the browser.
The API and SSE are typically used when you have a TagoDeploy with a on promise database. If you don’t have one, you can leave them blank so the system will use the fallback.
Below is an example of the default values:
{"us-e1": {api: "https://api.tago.io",realtime: "https://realtime.tago.io",sse: "https://sse.tago.io/events",},"eu-w1": {api: "https://api.eu-w1.tago.io",sse: "https://sse.eu-w1.tago.io/events", },
