Test Decoder Feature
Under the Device>Payload Parser and Integrations>Connectors tabs, it would be EXTREMELY helpful to have a small tool that allows you to input a payload and port number to test if either the default Connector decoder or any custom parsers are properly parsing the payload.
TTN has this feature and it’s very helpful (see screenshot attached)
It’s a bit more complicated but you can achieve the same effect using the simulator on a device and checking its output.
