Custom Widgets have always been the way to make a dashboard truly yours. But writing one meant coding it from scratch. Now, TagoIO AI can do that work for you.
Describe the widget you need, and the AI writes it directly on your Normal or Blueprint Dashboard. You can share an image of what you have in mind, explain your data, and watch the AI build a widget that reflects your vision. It all runs on the architecture you already have in place, in minutes.
What you can build with it:
- Full-dashboard widgets that cover the entire canvas with a single, cohesive view.
- Customized charts shaped around your data, not the other way around.
- Combined views, like a map and a table working together in the same widget.
- Step-by-step wizards to guide users through complex installation procedures.
Everything works with your existing devices and variables. On Blueprint Dashboards, widgets follow device selection automatically. Describe it once, and it works across your entire fleet.
Open the AI panel on any dashboard and describe the widget you’re picturing. You’ll see the first version in minutes.
