Watch and learn how a feature works before you build with it. TagoIO Academy lives inside TagoIO and gives you short, practical videos that show the real interface and real examples, so you can copy the steps directly into your own setup.
Each video runs 2 to 4 minutes and stays focused on one feature, so you learn what you need and get back to building.
Here are some topics we cover:
How to Create a Custom Widget using AI
What is TagoIO Audit Log?
What is TagoTiP MQTT and how to use it
What are TagoIO Actions?
How to Speed Up Custom Widget Development Using Ngrok
What are TagoIO Entities?
Adding Team Members to your TagoIO Profile
Having the videos next to your work changes how you learn. Instead of sitting through a training session weeks before you need something, you open a video the moment you are about to use the feature, which is exactly when the knowledge sticks.
That timing also gives you more confidence to act, because you can watch the steps run once before running them yourself, and that small preview matters a lot when a mistake would cost you.
The same effect scales to your team. When everyone learns from the same short video, configurations start looking alike across projects, and you stop ending up with five versions of the same setup that nobody else can read.
New hires feel this first, since they ramp up without booking time with a senior engineer, but it reaches further than the dev team. Product managers, data analysts, and business users can finally understand how a feature works without reading technical docs, which means more people in your company can actually use TagoIO.
The current library covers Devices, Entities, Actions, Files, Secrets, Audit Log, Team Members, TagoRUN, Custom Widgets, and all four TagoTiP protocols (HTTP, MQTT, TCP, UDP). More is coming soon.
How to access
To access the TagoIO Academy, open the side menu, click your profile, then Help & Support, then Academy.
The Academy will keep growing based on what the community asks for. What topic should we cover next?
