Hi Fabiano, thanks for checking this.
I checked the Forward uplink data message, there is no variable with a field variable. This is the payload decoder (its Dragino LHT65N)
function str_pad(byte){
var zero = '00';
var hex= byte.toString(16);
var tmp = 2-hex.length;
return zero.substr(0,tmp) + hex + " ";
function datalog(i,bytes){
var Ext= bytes[6]&0x0F;
var bb;
if((Ext==‘1’)||(Ext==‘9’))
bb=parseFloat(((bytes[0+i]<<24>>16 | bytes[1+i])/100).toFixed(2));
else if(Ext==‘2’)
else if(Ext==‘4’)
var Exti_pin_level=bytes[0+i] ? “High”:“Low”;
var Exti\_status=bytes\[1+i\] ? "True":"False";
bb=Exti\_pin\_level+Exti\_status;
else if(Ext==‘5’)
bb=bytes[0+i]<<8 | bytes[1+i];
else if(Ext==‘6’)
bb=(bytes[0+i]<<8 | bytes[1+i])/1000;
else if(Ext==‘7’)
else if(Ext==‘8’)
var cc= parseFloat(((bytes[2+i]<<24>>16 | bytes[3+i])/100).toFixed(2));
var dd= parseFloat((((bytes[4+i]<<8 | bytes[5+i])&0xFFF)/10).toFixed(1));
var ee= getMyDate((bytes[7+i]<<24 | bytes[8+i]<<16 | bytes[9+i]<<8 | bytes[10+i]).toString(10));
var string=‘[’+bb+‘,’+cc+‘,’+dd+‘,’+ee+‘]’+‘,’;
return string;
function getzf(c_num){
if(parseInt(c_num) < 10)
c\_num = '0' + c\_num;
return c_num;
function getMyDate(str){
var c_Date;
if(str > 9999999999)
c\_Date = new Date(parseInt(str));
else
c\_Date = new Date(parseInt(str) \* 1000);
var c_Year = c_Date.getFullYear(),
c_Month = c_Date.getMonth()+1,
c_Day = c_Date.getDate(),
c_Hour = c_Date.getHours(),
c_Min = c_Date.getMinutes(),
c_Sen = c_Date.getSeconds();
var c_Time = c_Year +‘-’+ getzf(c_Month) +‘-’+ getzf(c_Day) +’ ‘+ getzf(c_Hour) +’:‘+ getzf(c_Min) +’:'+getzf(c_Sen);
return c_Time;
function Decoder(bytes, port) {
var poll_message_status=(bytes[6]&0x40)>>6;
var Connect=(bytes[6]&0x80)>>7;
var decode = {};
switch (poll_message_status) {
case 0:
if(Ext==0x09)
decode.TempC_DS=parseFloat(((bytes[0]<<24>>16 | bytes[1])/100).toFixed(2));
decode.Bat_status=bytes[4]>>6;
else
decode.BatV= ((bytes[0]<<8 | bytes[1]) & 0x3FFF)/1000;
decode.Bat_status=bytes[0]>>6;
if(Ext!=0x0f)
decode.TempC_SHT=parseFloat(((bytes[2]<<24>>16 | bytes[3])/100).toFixed(2));
decode.Hum_SHT=parseFloat((((bytes[4]<<8 | bytes[5])&0xFFF)/10).toFixed(1));
if(Connect==‘1’)
decode.No_connect=“Sensor no connection”;
if(Ext==‘0’)
decode.Ext_sensor =“No external sensor”;
else if(Ext==‘1’)
decode.Ext_sensor =“Temperature Sensor”;
decode.TempC_DS=parseFloat(((bytes[7]<<24>>16 | bytes[8])/100).toFixed(2));
else if(Ext==‘2’)
decode.TempC_TMP117=parseFloat(((bytes[7]<<24>>16 | bytes[8])/100).toFixed(2));
else if(Ext==‘4’)
decode.Work_mode=“Interrupt Sensor send”;
decode.Exti_pin_level=bytes[7] ? “High”:“Low”;
decode.Exti_status=bytes[8] ? “True”:“False”;
else if(Ext==‘5’)
decode.Work_mode=“Illumination Sensor”;
decode.ILL_lx=bytes[7]<<8 | bytes[8];
else if(Ext==‘6’)
decode.Work_mode=“ADC Sensor”;
decode.ADC_V=(bytes[7]<<8 | bytes[8])/1000;
else if(Ext==‘7’)
decode.Work_mode=“Interrupt Sensor count”;
decode.Exit_count=bytes[7]<<8 | bytes[8];
else if(Ext==‘8’)
decode.Exit_count=bytes[7]<<24 | bytes[8]<<16 | bytes[9]<<8 | bytes[10];
else if(Ext==‘9’)
decode.Work_mode=“DS18B20 & timestamp”;
decode.Systimestamp=(bytes[7]<<24 | bytes[8]<<16 | bytes[9]<<8 | bytes[10] );
else if(Ext==‘15’)
decode.Work_mode=“DS18B20ID”;
decode.ID=str_pad(bytes[2])+str_pad(bytes[3])+str_pad(bytes[4])+str_pad(bytes[5])+str_pad(bytes[7])+str_pad(bytes[8])+str_pad(bytes[9])+str_pad(bytes[10]);
if(bytes.length==11)
return decode;
break;
case 1:
for(var i=0;i<bytes.length;i=i+11)
var da= datalog(i,bytes);
if(i=='0')
decode.DATALOG=da;
else
decode.DATALOG+=da;
return decode;
break;
default:
return {
errors: \["unknown"\]
