Suggested improvement: direct CRa LoRaWAN support
some time ago I asked for your help with connecting CRa LoRaWAN
(https://www.cra.cz/internet-of-things-connecting-to-the-lora-iot-network)
network with TagoIO so I could use my GPS tracker Moko. See here:
https://community.tago.io/t/data-transfer-from-the-cra-lorawan-network-to-tagoio
Unfortunately I couldn’t get it to work.
Now I bought TrackerD from Dragino:
http://wiki.dragino.com/xwiki/bin/view/Main/User%20Manual%20for%20LoRaWAN%20End%20Nodes/TrackerD
I have a very good experience with Dragino, so I asked them for help
connecting CRa LoRaWAN and TagoIO for TrackerD operation.
They spent a few days on it, modified the payloadparser for me, but
unfortunately it doesn’t work either.
According to Dragino’s statement (sent in the attachment), it is not
possible to properly connect the CRa network to TagoIO because of the
database on TagoIO.
When I start the live data analyzer, I can see that the data from the
CRa network is coming, but unfortunately it is not possible to save
and work with it.
Could you please take a look at how to get the CRa network working
together with TagoIO? It would be ideal if you could add direct CRa
network support on TagoIO like other LoRaWAN networks.
You can arrange test access to the CRa network here:
https://old-admin.iot.cra.cz/Freemium/
Alternatively, I can provide you with my account on the CRa network so
you can see what it takes to add direct support on TagoIO.
Thank you
Petr
HI Petr
You are having this response because you are passing your device in a parser that is not validated.
To be able to make your connector work you will have to make some changes in your Payload Parser. I believe this documentation can help you to achieve your goal: Building your own Parser, Payload Parser.
Regards
Mauro Kusiak
Hi Petr,
I’m moving this topic to the category Devices and Connectors as it is not actually a feature request.
