Source Control Best Practices
Greetings,
My TagoIO implementation involves numerous custom payload parsers, analysis scripts and custom widgets. In all of these cases, code is cut & pasted from an external source into the respective Tago editors and saved.
While this works, it’s fairly clunky as any source control must be implemented externally.
Is there a recommended best practice for implementing conventional source control (e.g. git) for custom scripts & code used by TagoIO?
Hello @info1,
You can use any Git-based hosting service such as GitHub, GitLab, Bitbucket, or any other platform you prefer.
As a reference, you can take a look at this public repository that contains a Kickstart RTLS application:
https://github.com/tago-io/analysis-kickstarter-rtls
As you can see, all Analysis scripts are hosted there. You can use this repository as a starting point to structure your own project and manage your code with proper version control.
For running Analyses externally or deploying them to TagoIO, we use the @tago-io/cli tool:
https://www.npmjs.com/package/@tago-io/cli
I strongly recommend using this CLI, as it significantly simplifies the deployment and management process.
