I would like to have a widget, similar to the heatmap but that controls soil moisture based on the data logging sent by the sensor.
The value in the scale must be from 0 to 100%, using the colors as shown in the image (Soilmoisture Index)
As background you could use an image of the map seen from the satellite in static mode (jpg o png image or http link), or use openstreetmap.org and enter the exact point using the sensor coordinates sent in the sensor metadata.
The new widget will have the name: Soil moisture Map, very useful for precision agriculture but also for controlling soil moisture in lawns and public parks
I’m
looking for the same feature. I need something like this for the moisture
monitoring of flat roofs and floor structures in apartments.
Individual color adjustment of the scale would be good.
We want to set up moisture monitoring for our industrially
prefabricated residential buildings in solid wood construction. I’m the technical chief
developer here and I’m currently looking at various possibilities (including
Lorawan with tagoio).
We already have a heatmap widget, although I understand it may not fully meet your specific requirements. What you’re looking for is achievable using a custom widget.
R.juch, One of our team members, has already reached out to you by email to help you in the best way possible and to better understand your goals, especially regarding your moisture monitoring setup.
If you need anything else, we’re here to help. Thank you!
