Search devices using eui?
@Andrew Sevil
Is there a way to search all my devices (most are LoRaWan) by EUI? Currently the only way I can do it is to add the last 4 characters of the eui to the name, which is really clunky and unreliable (for example a client is able to edit name to their liking). The eui doesn’t show in the device list, only when the device is selected can it be seen.
@Fabiano Eger
hi, @sevils for this case you can use tags. Just go to your device and create the tags needed. You need to insert tags in all of your devices.
This is searchable in the device list.
Adding DevEUI’s as a tag for ever single sensor seems like a workaround… All of our other IoT tools let us search by DevEUI’s.
Going in and adding tags for over 100 devices is cumbersome. Is there a way you can expose the DevEUI’s as a column in the Device page so that we can see the values and easily search for them when needed?
