Hopefully someone can help. Need to config a graph with 2 axis where I want to set the range of the scale of each axis. I can select it fixed instead of dynamic and it applies for both sides, but I couldn’t find a way to set up the range for each axis as the following images.
Hello everyone! Just to clarify, am I correct in understanding that there’s no way to manually adjust the ranges for multiple axes according to the specific readings of the sensor?
