Printable charts
I was wondering how can I implement a button to print the chart or export to .pdf .jpg .png like the charts of this example:
https://www.highcharts.com/demo/highcharts/line-boost
Do I need to implement a custom widget using the highcharts.js library or is there an easier way?
A good and quick workaround you can do is… do right click on a widget, and then depending on your browser you can sabe direclty the image, or open the .png in another tab. you must click a blank part of the graph tho, see below.
Right click:
What Browser are you using?
I tryed with Chrome and Edge and it saves the image with different colors and without informations…
the image was supposed to be as following:
but when I save it as png it appears like this:
not showing the date/time and value of the variable…
