Hi All - great support so far in this community, thanks!
So I have a NB device and have it successfully using MQTT to upload to Tago.io. The problem I have is the MQTT connection seems very unreliable with regular failures and often consecutive failures prompting me to reset the device. As is, I’m not confident to deploy these devices into the field.
I’m wondering if I can connect using the device default of UDP? Or maybe coAP? My understanding is I’d need a network and connector (which I’ve created) but I don’t understand how I configure the device’s firmware to connect.
Thanks Vitor. Seems like another rabbit hole of tech I’m probably going to struggle with lol.
If I step back, is there a reason qhy the MQTT connection is so unreliable?
Here’s a typical output from my terminal when the device wakes up to send data: NSE01 NB-IOT Soil Moisture & EC Sensor Image Version: v1.0.0 NB-IoT Stack : D-BC95-002 Protocol in Used: MQTT [8316]NBIOT has responded. [9354]Echo mode turned off successfully. [10442]The IMEI number is:868411056759764. [11523]The IMSI number is:505013535346199. [13672]Turn on PSM mode successfully. Currently set frequency band:28 [15806]Signal Strength:13 [20540]Upload start:0__ [25576]remaining battery =3231 mv HEX:fe 03 06 00 d2 06 7b 00 10 ad ce [26766]water_soil:2.10 [26793]temp_soil:16.59 [26820]conduct_soil:16 [37997]Failed to open the MQTT client network [41548]Close ACK not received… [44084]Close ACK not received… [44120]Failed to close the port [45156]End of upload__
Sometimes it’s fine for several connections after a power cycle then it seems to fail repeatedly. Other times a full power cycle makes no difference. I don’t believe it’s an issue with the device or the network connection, more that the Tago server isn’t responding for some reason.
Hi Rob,
It seems we already solved that by ticket system, as it seems that you resetting the device fixed the issue, let me know if you have additional questions.
I realise this is old but can you shed any light on your settings in the NSE01? I am trying to replicate using the NBSN95a wihch is effectively the same unit but am getting nowhere
