@Marcin Wx
Need to run MQTT with TLS. My MQTT client asks to import a certificate to run TLS. Where to get the certificate from?
@Marcin Wx
@Marcin Wx
Thanks, I need to use mosquito/tls to publish data to tago.io however it fails due to certificate verify error. Where to get the CA file from to enable publishing data with mosquitto_pub? The command I use is as below:
mosquitto_pub -h mqtt.tago.io -p 8883 -u token -P abcdefgf-abc-1234-5678-abcyyyyexxxx -m testmsg -t testtopic -d
I think I need to provide CA file with mosquitto --cafile option. Can you help?
Hi!
Do you have any updates on the custom certificate update? Are we still using auto TLS certs?
Thank you.
We haven’t implemented custom certificate support for the TagoIO Public Broker, which continues to use well-known CA authorities for auto TLS certificates.
For custom CA certificates or mTLS requirements, you can deploy your own MQTT broker through TagoDeploy. Currently, this requires a TagoDeploy project, but we’re developing a standalone version that will work with standard TagoIO multi-tenant accounts.
You can explore TagoDeploy options here: https://tago.io/deploy
https://community.tago.io/t/tagodeploy-mqtt-broker-service
