I have the following ‘standard’ decoder that works in TTN but trying to get it to work in Tago’s payload parser
Can anybody help me in converting this to work on Tago connector?
Thank you.
* Payload Decoder for The Things Network
* Copyright 2021 Milesight IoT
* @product WS52x
function Decoder(bytes, port) {
var decoded = {};
for (var i = 0; i < bytes.length; ) {
var channel\_id = bytes\[i++\];
var channel\_type = bytes\[i++\];
// VOLTAGE
if (channel\_id === 0x03 && channel\_type === 0x74) {
decoded.voltage = readUInt16LE(bytes.slice(i, i + 2)) / 10;
i += 2;
// ACTIVE POWER
else if (channel\_id === 0x04 && channel\_type === 0x80) {
decoded.power = readUInt32LE(bytes.slice(i, i + 4));
i += 4;
// POWER FACTOR
else if (channel\_id === 0x05 && channel\_type === 0x81) {
decoded.factor = bytes\[i\];
i += 1;
// POWER CONSUMPTION
else if (channel\_id === 0x06 && channel\_type == 0x83) {
decoded.power\_sum = readUInt32LE(bytes.slice(i, i + 4));
i += 4;
// CURRENT
else if (channel\_id === 0x07 && channel\_type == 0xc9) {
decoded.current = readUInt16LE(bytes.slice(i, i + 2));
i += 2;
// STATE
else if (channel\_id === 0x08 && channel\_type == 0x70) {
decoded.state = bytes\[i\] == 1 || bytes\[i\] == 0x11 ? "open" : "close";
i += 1;
else if (channel_id === 0xFF && channel_type == 0x3F) {
decoded.outage = bytes\[i\] == 0xFF ? 1 : 0;
} else {
break;
return decoded;
* bytes to number
function readUInt16LE(bytes) {
var value = (bytes\[1\] << 8) + bytes\[0\];
return value & 0xffff;
function readUInt32LE(bytes) {
var value = (bytes\[3\] << 24) + (bytes\[2\] << 16) + (bytes\[1\] << 8) + bytes\[0\];
return (value & 0xffffffff) >>> 0;
