Meet the New TagoIO API Documentation
One home for everything. Faster ramp-up. Cleaner integrations.
We’ve been steadily refining our docs based on what you ask for most: clarity and speed. Today, we’re rolling out the next step: the new API documentation, now merged into the same platform as TagoIO, TagoRUN, and TagoDeploy. You’ll see API right in the navbar beside the others. Simple, familiar, and finally in one place.
Try it live—right in the docs
Testing shouldn’t be a scavenger hunt. On the new platform, you can:
  • Run API requests directly from the docs (no extra tools required)
  • Preview real JSON responses
  • Copy ready-to-run code in your language of choice: cURL, Python, Go, Node.js, Rust, and Swift
It’s straightforward: pick an endpoint, plug in your values, send the request, and review the response. If it works here, it’ll work in your app. That’s the point.
And yes—there’s more coming. We’re adding Python and JavaScript SDK snippets directly to each endpoint soon, so you can switch between raw HTTP and SDK-based calls without changing tabs or hunting for examples.
Where to find it
You can check the new API documentation right now by clicking here.
