Dear all,
I had to draw a circle around the device last location and did some workaround:
1. added a variable to the payload, “range” as a fence format:
“variable”: “range”,
“value”: “Range: 36.75”,
“location”: {
_"type": "Point",_
_"coordinates": \[_
_-46.63629,_
_-23.595664_
_\]_
“metadata”: {
_"event": "Accuracy: 36.75",_
_"eventColor": "black",_
_"geolocation": {_
_"type": "Point",_
_"radius": 36.75,_
_"coordinates": \[_
_-23.595664,_
_-46.63629_
_\]_
_}_
2. Changed geofence options in the widget to show only one value for the “range” variable.
Then the result is this:
Would be nice if the map widget have this feature (location.radius or metadata.radius or metadata.geolocation.radius ) on the variable without adding a new variable to simulate it.
Color option and a button to switch on/off the view also would be welcome.
Thanks in advance
