Today, we’re launching the TagoDeploy MQTT Broker Service, a comprehensive IoT messaging solution that empowers organizations to deploy, manage, and scale their own private MQTT infrastructure with enterprise-grade security and control.
TagoDeploy represents your dedicated, private instance of the TagoIO platform—providing complete isolation and administrative control that shared environments cannot deliver. This new MQTT Broker service marks a significant expansion of TagoDeploy’s capabilities, enabling organizations to establish secure, high-performance IoT data pipelines directly within their private ecosystem.
The TagoDeploy MQTT Broker Service delivers a fully-managed, scalable MQTT infrastructure with advanced client authentication, granular access control lists (ACLs), real-time connection monitoring, and configurable data pipelines—all integrated seamlessly within the TagoDeploy platform.
The architecture operates through a secure, three-stage data flow: Device authentication and connection establishment, permission-based topic access control through assigned Groups, and automated data routing to configured Pipeline destinations based on publication topics.
Enterprise-Grade Capabilities
Comprehensive Configuration Management: Complete service configuration
through the TagoDeploy platform interface -
Multi-Broker Architecture: Deploy and manage multiple MQTT brokers within a single platform instance
Advanced Security: Full TLS encryption with custom certificate management capabilities
Flexible Deployment Options: Available as integrated TagoDeploy service or standalone implementation
Dedicated Infrastructure: Exclusive resource allocation ensuring consistent,
predictable performance for mission-critical applications -
Global Availability: Deploy across 12+ AWS regions for optimal latency and regulatory compliance
How it Works
Create the MQTT Service
Select the region, name, and instance type (TagoDeploy or standalone).
Deploy the service and monitor progress via the Deployment Console.
Retrieve the MQTT Endpoint
- Copy the endpoint from the Domains section.
Configure Authentication
- Generate a Client ID with a username and password.
Define Groups
- Specify which topics each group can publish or subscribe to.
Set ACL
- Link authentication methods to groups and assign permissions.
Create Network and Payload Parser
- Set up a parser to extract device serial numbers and route data to the appropriate device.
Configure a Pipeline
Set the API endpoint for your target instance.
Select which topics will use the pipeline.
Add profile authorization and network tokens.
Send Data
- Use your configured authorization and topics to transmit data.
We’re also announcing the upcoming release of our standalone MQTT Broker service, enabling organizations to leverage TagoDeploy’s MQTT infrastructure without requiring a full TagoDeploy instance deployment.
