I’m trying to understand how the tago integration system with tagoCore works.
In my Tago account, I have a device, some actions and analyses. I would like to know how I can access these variables from tagoCore, make my device able to access this data, etc.
I would like to know how I can access and send data normally, as if it were tago.io. It is possible?
TagoCore shows as connected in integration, but I don’t know how to proceed.
With the TagoIO integration, you can manage instances of TagoCore and clusters. You can access your connected instances here. It’s not possible to access the data directly from the TagoCore. To access the data, you need to send the data using an action of the type “Insert data into TagoIO” in your TagoCore.
When I activate TagoCore and make a connection with Espo32 to MQTT, http://x.x.x.x:1883, it shows as connected. When I click on the button to call an action I created, it also shows the results inserted in tagoCore.
The problem is that the selected topic is not being sent to expo32, or expo32 is not receiving it correctly. The problem is that before I switched from tago.io to TagoCore, it worked correctly.
Do you have any suggestions for me to fix this?
