Input Form widget - Changing Field configuration
Hello!
I would like to change some settings in the Field tab of the Input Form and I want to know if they are possible. Can someone help me with them?
  1. In case the “field type” is TEXT: Is it possible to increase the space of filling the field?
In the original configuration, as we type, the previous text disappears… I would like to see the complete text as I type it.
  1. When I click on the dashboard with Input Forms, the last information sent to the bucket appears in the field, and that cannot happen! The field must always be clear, just with my “Placeholder” information. The option “Clear all Fields” is already checked on the buttons, but the problem persists. How can I solve it?
Thanks in advance!
Hello carolina.
  1. The field auto fits the whole widget available space, if you increase the width of your widget you are going to notice the difference, so you can not change a single field width or height.
  2. In your field settings, there is an option called “Default value”, change it from “Last” to “Fixed”, and it will solve your problem. The option “Clear all fields” means after you clicked to submit this form, the field will be cleared.
I hope this helps you.
Filipe
Much of my problem was solved with your tips.
Thank you very much, Filipe!
We are glad for that!
Take a quick look around in our community, I’m sure you will find some interesting topics about our Widgets.
