Input Form Improvement
In the input form, when using a field type of “Dropdown,” you can configure your options. However, the configurator doesn’t allow you to reorder them. This means that if you need to insert an option at a specific position, you have to manually edit each entry instead of simply rearranging the order.
Hello chrisautomates,
Thank you for bringing this to our attention. A task has been created for the Frontend team to evaluate and implement this new reorder functionality for dropdown options. This will be reviewed in the second quarter of 2025, since the team has several other tasks in the pipeline, it may take some time to be prioritized.
Just to clarify, this feature will only be available when using the “Configure options” setting for dropdowns. If you have any more questions or need further assistance, please let me know!
