In Analysis when using sendData how do you write a floating value
I couldn’t find an example of this.
Here is my sendData filter:
const pulses_per = {
  variable: "gallons_per_sample",
  value: num_pulses_per_sample/pulses_per_gallon,
  unit: "gallons"
Will it write a floating value automagically, or do I have to convert to a float?
Thx,
M
Hello @marlanw,
Yes, when you send data, the value field accepts multiple types: string | number | boolean. Your calculation num_pulses_per_sample / pulses_per_gallon will produce a JavaScript number (which includes floating-point values), and TagoIO will store it exactly as calculated.
In some cases, floating-point operations may generate long decimal values. If you want to limit the number of decimal places, you can use the built-in toFixed() method.
  value: Number((num_pulses_per_sample / pulses_per_gallon).toFixed(2)), // e.g., 3.14
  unit: "gallons"
Let me know if you need anything else.
