We put the new Admin UI into Beta back in March. Since then, a lot of you have used it daily, broken it in ways we did not expect, and told us exactly what was wrong. That feedback turned into a long list of fixes. The result is a new design that is faster to work in and ready to be the default.
What is changing
The new design looks slightly different from the current one. Most of your day-to-day work stays in the same place, but the layout, spacing, and some components have changed. That difference is the reason this post exists: the way your dashboards, widgets, and portals render can shift under the new design, and your end users will see that change.
What you need to do
Review your dashboards, widgets, and portal layouts under the new design and adjust anything that does not look right. The goal is a smooth handoff to the people who actually use your portals, so they never notice a rough edge.
You can do this now. Switch to Beta today and see exactly how your current portal and dashboards will render in the new UI. While both designs are available, you can compare them side by side and fix layout issues before they reach anyone.
Today, under your RUN settings, you can already see the two URLs of your RUN. Use them to preview how your portal will look under each design before the switch.
The date that matter
July 27, 2026: portals and dashboards built on RUN reflect only the new UI design (*). This is about how your users see it, the RUN users. Test and adjust yours before this date so nothing surprises them after the cutover. *if you have a Custom Domain Add-on see below.
A few things that do not change
The URL of your user portal defined in RUN stays the same. Nothing you have shared with customers needs to be updated.
If you run a Custom Domain, you can switch your RUN portal back to the current (legacy) design if you need more time to adjust your layouts. This legacy UI for Custom Domain will be available for 12 months - until July 31, 2027. Keep in mind that from now on, no updates or fixes will be made in the legacy version. We recommend you switch to the new ADMIN UI as soon as you can to benefit from new features and fixes.
Help us land this well
If something does not look right during your tests, post it here in the community or open a ticket through support.
Thank you for building with TagoIO.
