How to publish hex values to the MQTT?
I have a hex string sequence: mySeq = “01fa02” to be published as sequence: 0x01 0xFA 0x02.
I am using Python in the Analysis and I don’t find a solution, please, How do I do it?
Hi Campos Silva,
If you add this code snippet:
byteSeq = bytes.fromhex(mySeq)
for byte in byteSeq:
    print(hex(byte))
You’ll be able to print out each byte in hexadecimal format
Hope this helps!
