How to notify RUN users?
I would like to notify RUN users, I used the example ‘send dynamic email, sms, and push notification’, following your instructions, but the analysis does not find the RUN user ID, and when I try to search using listUsers I also do not find any ID. Is there some configuration that I must change to be able to find the IDs
Hi p.haemmerle,
To better assist you with notifying RUN users and resolving the issue of not finding the RUN user ID, could you please share the code you are currently using? This will help us identify any potential configuration issues and provide you with more precise guidance.
