How to install TagoCore on Raspberry PI
@Douglas Zuqueto
In this tutorial we will learn how to install TagoCore on Raspberry PI.
Dependencies
  • Raspberry PI 4
  • Raspberry PI OS
  • TagoCore binary(ARMV7)
How to
Step 1
Create folder structure, download and test tagocore binary.
# 1º
cd
# 2º
mkdir tagocore
# 3º
cd tagocore
# 4º
wget https://downloads.tagocore.com/tagocore.tar.gz -O tagocore.tar.gz
# 5º
tar -zxvf tagocore.tar.gz
# 6º
rm tagocore.tar.gz
# 7º
./tagocore
Output
pi@raspberrypi:~/tagocore $ ./tagocore
Plugin "SQLite" is now fully loaded.
Access http://localhost:8888 to use TagoCore!
The tagocore service is running on port 8888!
Step 2
Create systemd file for the TagoCore service.
# 1º
cd /lib/systemd/system/
# 2º
sudo vim tagocore.service
Put the contents in tagocore.service:
[Unit]
Description=TagoCore Server
Documentation=https://tagocore.com/
Wants=network-online.target
After=network-online.target
[Service]
User=pi
Group=pi
ExecStart=/home/pi/tagocore/tagocore
Restart=on-failure
[Install]
WantedBy=multi-user.target
Alias=tagocore.service
Done! Now, reload daemon and start the tagocore service.
# 1º - Daemon reload
sudo systemctl daemon-reload
# 2º - Service Status
sudo systemctl status tagocore
# 3º - Service start
sudo systemctl start tagocore
Step 3
Check the tagocore service logs:
Output:
pi@raspberrypi:/lib/systemd/system $ sudo systemctl status tagocore
● tagocore.service - TagoCore Server
     Loaded: loaded (/lib/systemd/system/tagocore.service; enabled; vendor preset: enabled)
     Active: active (running) since Mon 2021-12-20 14:08:56 -03; 5s ago
       Docs: https://tagocore.com/
   Main PID: 18130 (tagocore)
      Tasks: 11 (limit: 4915)
        CPU: 3.621s
     CGroup: /system.slice/tagocore.service
             └─18130 /home/pi/tagocore/tagocore
Dec 20 14:08:56 raspberrypi systemd[1]: Started TagoCore Server.
Dec 20 14:08:59 raspberrypi tagocore[18130]: Plugin "SQLite" is now fully loaded.
Dec 20 14:08:59 raspberrypi tagocore[18130]: Access http://localhost:8888 to use TagoCore!
Done!
Finish
TagoCore is running on: http://RASPBERRY_IP:8888
Regards,
Douglas Zuqueto
@Matheus Benachio
Thank you for making this awesome tutorial, Douglas!
This will help a lot of people who want to install TagoCore on their Raspberry Pis
ERROR 403
Resolving downloads.tagocore.com (downloads.tagocore.com)… 108.138.189.90, 108.138.189.44, 108.138.189.60, …
Connecting to downloads.tagocore.com (downloads.tagocore.com)|108.138.189.90|:443… connected.
HTTP request sent, awaiting response… 403 Forbidden
2022-04-06 18:12:45 ERROR 403: Forbidden.
Hey @gabriele83x
The link in the post is outdated, to download tagocore you need to specify the actual version, so this is the full command to download it:
wget https://downloads.tagocore.com/v0.3.2/tagocore-v0.3.2-linux-armv7.tar.gz -O tagocore.tar.gz
Hope that was helpful, let me know if you have any other questions.
I have already in use 8888 and 8999. Is possible to change this ?
I have change my extra service, thank you!!!
Very easy to follow tutorial, this guide is incredibly helpful for new users, especially if you’re starting with Raspberry/TagoIO
Dear, because in Tagocore for raspberry in Store are not present Node-red??
