How to create a indoor tracking application using Beacons
:warning: This tutorial is deprecated. There is a much simpler way to install a plug-and-play application that can be imported into your account and used as a template for full customization. You can find it here: Kickstarter.
In this article, we will learn how to set up a dashboard to track indoor sensors. In the example, we have BLE beacons that can be added in a floor plan image by the end-user. Then, a tracker (for example, based on LoRaWAN) will scan the beacons and send their IDs to TagoIO.
By following all the steps in this article you will end up with:
  • An automatic trigger to run an analysis that emulates data for your sensors
  • An analysis to emulate data for your devices
  • An analysis to handle the data coming from your emulated devices
  • A dashboard to visualize the sensors, set up beacons, and sensor.
Setting up the device
For this article, we will need one device to store our data.
To create a device you need to go to https://admin.tago.io/devices
  1. Click on the “Add device” button located at the right top corner.
  2. Then look for the “Custom HTTP” connector and click on it
  3. Give the device a name and create it.
  4. You will be redirected to the device page.
Setting up the dashboard
You can get the dashboard that we will use clicking here.
You will select the device that we created when it asks it.
After selecting the device you will be redirected to the dashboard.
Setting up the analysis
Data emulation analysis
To get this analysis you should go to: http://admin.tago.io/template/5f68f1e2dacc24001db6c3ce
The only thing we need to do here is to set up the Environment variable.
  1. Enter the following link: https://admin.tago.io/account/
  2. Select your Profile.
  3. Enter the Tokens tab.
  4. Generate a new Token setting Expires to Never.
  5. Press the Copy Button and place it at the Environment Variables tab of the analysis.
Data handler analysis
To get this analysis you should go to: http://admin.tago.io/template/5f68f25bdacc24001db6cf41
Here we will need three things:
  • The account (that we already have)
  • The config token
  • The dashboard id
Config token
The config token is a device token. This device is the one that we created at the beginning of this article.
To get it you just need to go to the device page and copy the token.
Dashboard id
The dashboard id is a unique identifier that each dashboard has.
To get this id:
  1. Go to the dashboard.
  2. Click on the pencil icon on the top right corner.
  3. Click on the gear icon.
  4. Click on the “More” tab.
  5. Copy the dashboard id.
Now we just need to go to the last analysis that we added to our account and add the needed info.
On the “Environment variables” tab, change the data according to the tokens and the id that you have, then click on the save button.
After this, our set up process is done.
How to use the dashboard
Basically there are three tabs on our dashboard.
Layers tab
This tab simply shows the trackers that you have and where they are on the map.
Beacons setup tab
In this tab, you have a form to create new beacons.
A table to remove a beacon.
And you have an “Image Marker” widget.
After you created a beacon, you can click on the pencil icon on the “Image Marker” widget to enable the editing mode.
To add a beacon to the image:
  1. Click where you want it to be
  2. Select the beacon on the dropdown
  3. Type a label
  4. Click on save
Trackers setup tab
In this tab, you can create, edit, and remove the trackers.
The data for each tracker is stored in a different device, so remember to create a device for each tracker.
To complete the configuration of this tab your need to click on the button with the pencial icon located at te top right corner to enable the edit mode.
After it, you need to click on the three dots icon button on the “Register/edit tracker”.
On this screen go to the user control section, and select the “Beacon Finder Handler” analysis on the “Run analysis when submitting the form” field.
@Rakel Sigurjónsdóttir
Few questions.
I am trying to use this tutorial.
The Data emulation analysis when should that run? It is not mentioned anywhere how it should be called or if it should just run once in the beginning or what.
I had a bit of a problem with the Data handler analysis
got error after error “name is not defined” “Cannot read property ‘filter’ of undefined” W
as well as others as I tried to navigate through making the code work, but I think I might have made it worse although I got the analysis to run through.
In the dashboard itself I have added 3 beacons and a tracker. The beacon locations are visible under the “Beacon setup” tap, however nothing is visible on the layers tab, and no sign of the tracker info anywhere. Do you have any more detail on how this should work and maybe more visual data on this?
@FuJi Kok Fook-Kee
Hi
For the registration of tracker under the “Trackers setup tab”:
I also have the same issue/error “name is not defined” from the “Beacon Finder Handler” analysis when I tried to register a tracker (after add it in my device list using “custom https device”).
May I know to to resolve it?
@Adrian Sinton
I get install errors for both of those templates described above…?
@Phil Gutierre
HI @invent.bvi
Thanks for the information. We’re investigating this error. You can follow our updates through this link: Changelogs - TagoIO
Best regards,
The templates had been updated with fixed version of the tutorial.
Unable to find template information
I can’t find Layers tabBeacons setup tabTrackers setup tab.Do they need to be created by themselves?
