How to connect your MQTT Broker [Tip #20 Carolina from Support]
Hi y’all, Carolina from support here!!
Here we go with a quick tip: If you already use your own MQTT broker (EMQX, Mosquitto, HiveMQ, etc.), the TagoIO MQTT Relay is the easiest way to forward topics into TagoIO Devices while keeping your existing MQTT setup.
What it does:
  • Subscribes to topics on your broker and forwards payloads to TagoIO via a Network Integration and Connector.
  • Optional downlink: publish back to your broker using a secure Middleware Endpoint.
  • Open-source (Rust), high performance, supports TLS and Docker, and fully configurable via .toml or environment variables.
It has a quick setup, just follow our official documentation and here.
Why use it:
  • Keep your existing broker and topic structure.
  • Works for any server/Free plans.
  • Scales with your traffic and is simple to deploy in Docker.
I hope this tip helps the members of our community!!
Happy weekend,
