uRAD provides access to sensor data via an API. Using simple https calls with passed parameters to authenticate the request. (api docs: uRADMonitor_server_specs_02_comp.pdf ) I am able to use Postman to easily get the data I want but I am having trobule setting up a device in TagoIO to capture/visualize the data.
I selected the custom HTTPS device, I was also able to add in my required 2 parameter key/values but I don’t see a way to enter the GET uri.
