This tutorial shows how to use formulas in TagoIO Blueprint dashboards to compare string values and display user-friendly outputs. We’ll cover two common cases:
- Card widget: show “Online” or “Offline” based on a device status string.
- Chart widget: convert a string status into numeric values (1/0) for time-series visualization.
Some TagoIO widgets let you apply a formula to the incoming value. This is useful to:
- Map internal codes to readable labels (e.g., “on” → “Online”).
- Convert strings to numbers for charts or conditional visuals.
We’ll use the equalText helper in widget formulas to compare string values reliably.
Note: Image links are preserved from the original content. The final “end result” image for the chart is missing.
Prerequisites
- A Blueprint dashboard in TagoIO.
- Variables:
device_statusfor the Card widget example.lamp_statusfor the Chart widget example.
- A widget with a data source set to “Fixed” when applying a single-value formula.
Card Widget: Map “on” to “Online” and everything else to “Offline”
We’ll display the device_status variable in a Card widget and transform the raw value into a user-friendly label.
Enter edit mode:
- Click the pencil icon (top-right of the dashboard).
- On the Card widget, click the three dots menu and open the edit panel.
Configure the Card:
- Title: set to
Device status. - Options: disable “Show variable names” and “Show mini-chart” to keep the card clean.
- Title: set to
Add the formula:
- Go to “Formula and unit” and click “Enable formula”.
- Ensure the data source for this value is set to “Fixed”.
- Use this formula:
equalText("$VALUE$", "on") ? "Online" : "Offline" - Save the widget.
Notes:
equalTextcompares text without worrying about case sensitivity or extra spaces in many cases. If your data includes variations (e.g., “On”, “ON”),equalTexthandles them.- If you compare numbers, do not use quotes around the numeric literals. For example:
"$VALUE$" > 10 ? 1 : 0should become$VALUE$ > 10 ? 1 : 0when the incoming value is numeric.
End result preview for the card:
Chart Widget: Convert “on”/“off” to 1/0 for Step Line
We’ll visualize lamp_status history by converting the string value into numbers so the chart can plot it cleanly as a step line.
Create or edit the Chart widget.
Title: set to
Lamp status history. -
Data source:
- In “Data from”, select the variable that stores the lamp’s status, e.g.,
lamp_status. - Click the gear icon in the top-right of the “Data from” section to open “Visual” and “Formula and unit”.
Add the formula:
- Open “Formula and unit”.
- Click “Enable formula”.
- Use this formula:
equalText("$VALUE$", "on") ? 1 : 0
Visual settings:
- Go back to the main panel for the chart widget.
- In “Visual”, set “Line shape” to
Stepto show clear state transitions.
Save the widget.
After applying the settings above, you should see the series switch between 0 and 1 over time with a step line, where 1 represents “on” and 0 represents “off”.
