How to change the network/connector of existing devices without losing data [Tip #51 Carolina from Support]
Hey y’all! Carolina from support here!!
A customer reached out today with a common concern: they needed to migrate several devices from one LoRaWAN network (ChirpStack) to another (Senet) and were worried about losing their historical data, or having to delete and re-create each device manually.
The good news: you don’t need to delete anything! TagoIO allows you to update the network and connector of an existing device while keeping all data intact.
There are two ways to do it:
1. Via API: Use a PUT request to /device/{DeviceID} with the new network and connector IDs. Just make sure to delete the device tokens first (required before changing the network). See the API reference.
2. Via Analysis (best for bulk updates): Write a simple script using the TagoIO SDK to loop through all your devices, delete their tokens, and update the network/connector automatically. Perfect when you have dozens or hundreds of devices!
Hope this helps anyone facing the same migration challenge!
Happy week,
Hello Carolina. Love these tips.
This particular need seems like something that should be able to be accomplished from the admin console as well.
M
Hey @marlanw ,
So happy to hear you’re enjoying the tips posts! If you ever have ideas for future tips, feel free to share! Suggestions are always welcome :face_holding_back_tears:
And thanks for the feedback on having this available in the admin console! I’ve already passed it along to the team for consideration in future updates.
Happy Wekeend,
