How does the dashboard ordering system work in Tago Run?
Hello, good morning!
I’ve been having trouble with the ordering of dashboards in Tago Run. For example, I’d like users to see the “cad” dashboard first when they log into the application. However, I have a dashboard named “alarm” that always shows up first — which would make sense if the order were alphabetical. But even after renaming “alarm” to “zebra”, it still appears as the first dashboard.
Does anyone know how the dashboard ordering works in Tago Run and could help me solve this issue?
Hi Geovane Silva,
The dashboard order in TagoRun is not based on alphabetical order, but rather on the configuration defined in the Sidebar settings in Run on the admin page. This means that even if you rename dashboards, their display order will remain the same unless explicitly set in the sidebar configuration.
To control which dashboard appears first (for example, showing “cad” first), you can customize the sidebar by following the steps in this documentation: :link: Sidebar Customization Guide
Once set, the first dashboard listed in the sidebar will be the one that loads by default when users log in.
Let me know if you need help setting it up!
