Hiding Widgets/Buttons
Is it possible to hide a header button based on a variable value? If it is not can it be added to the existing widget?
If not, here is my scenario and let me know if I can solve using another method. I have a pump that can run in auto mode or manual mode. In manual mode I want to use a push button widget that controls the output via downlink (start/stop), but if the pump is in auto mode I do not want the user to be able to see the push button widget because it in fact has no function when in auto mode.
So either hiding a header button, the widget as a whole or something is what I am looking for.
Hi chrisautomates,
Currently, doesn’t exist a conditional option to display or hide Header Button. However, an effective workaround is to create two separate Blueprint Dashboards. One dashboard can be configured to display devices manually, while the other can be set to display devices automatically.
For more detailed guidance on setting up Blueprint Dashboards, please refer to our documentation: Blueprint Dashboard Concepts.
