I’m trying to set the time range of a graph to 7 days, but it is only going back a few hours. Is it a Free Plan limitation or something else?
Hi @danielelennertz,
There are no limitations on the Line Chart widget features in the Free plan. Looking at your screenshot, I assume the issue is related to the number of records (data points) being displayed in the widget. By default, the Line Chart is set to show up to 5,000 data points, but you can increase this limit to a maximum of 10,000.
If that’s the situation you’re running into, you can also take advantage of the Data Analytics feature. For example, you could use the Aggregate function to display the average value per hour (or whichever interval works best for you). This way, you’ll be able to visualize a longer time range without hitting the data point limit.
Thank you, the limit of data points was the problem. I tried the Data Analytics route and it worked
