I think this feature would be very powerful for the map widget, but I have not figured out a way to do the same thing.
What I would like is to create a pin that only shows the last location of say, 20 devices with tag “X”.
I would like to be able to create a pin that selects variable “Y” of every device that has tag “X”.
Then I could have a map of all sensor locations that would dynamically update as you add more devices with tag “Y”.
My current plan is to work around by creating a Mutable bucket, and run an analysis that deletes all entries and repopulates them with device locations with a based on a tag.
Thank you for contacting us and sharing your feedback. We appreciate your interest in creating a pin that only shows the last location of devices with a specific tag and variable.
Your current plan is correct. You can create a Mutable bucket and use an analysis to delete and repopulate the entries with the device locations based on a tag. This way, you can have a dynamic map of all sensor locations that matches your criteria.
We are glad to hear that you have found a workaround for your use case. We also think that your suggestion is valuable and we will consider it for future improvements. However, we cannot guarantee when or if this feature will be implemented soon.
Thank you for your understanding and patience. Please let us know if you have any other questions or concerns.
