Expire time of Device Token
I want to change the expire_time of created Device token, is there an API to edit the token parameters.
Thank you
Hi Hegde,
You can’t edit existing Device tokens.
You’ll need to create a new token in order to modify the permission time using this method.
You can also list all the tokens the device currently has using this method or delete any token using this method.
