I have an ESP32, a DHT11 and a ZMP101B. I’m trying to use the EmonLib library to read the voltage of the ZMP101B. I can do the voltage reading when I don’t implement the MQTT part, but when I implement the MQTT part, it stops reading the voltage.. the voltage is at “0V”.. the dht readings are still normal.
The same is true for other IoT platforms.
#include <stdio.h>
#include <WiFi.h>
#include <PubSubClient.h>
#include <ArduinoJson.h>
#include <DHT.h>
#include <EmonLib.h>
#define VOLT_CAL 85 // voltage calib
// MQTT definitions
#define MQTT_PUB_TOPIC "tago/data/post"
#define MQTT_USERNAME "test" // any value
#define MQTT_PASSWORD "66534b39-c363-41f8-b665-fd644a2423c9" // Device Token TagoIO
// WIFI
const char* ssid_wifi = "AndroidAP"; // WI-FI network SSID
const char* password_wifi = "cett0940"; // WI-FI network password
WiFiClient espClient;
// MQTT
const char* broker_mqtt = "mqtt.tago.io"; // MQTT broker URL
int broker_port = 1883; // MQTT broker port
PubSubClient MQTT(espClient);
DHT dht(25, DHT11); // (pin, type DHT)
EnergyMonitor emon5; // instance emon
//Prototypes
void init_wifi(void);
void init_MQTT(void);
void connect_MQTT(void);
void connect_wifi(void);
void send_data_iot_platform(void);
unsigned long millis_Time = millis();
float temperature_read;
float humidity_read;
double voltage_read;
void setup() {
Serial.begin(115200);
dht.begin(); // init DHT
init_wifi(); // func init wifi
init_MQTT(); // func init mqtt
connect_MQTT(); // func connect mqtt
emon5.voltage(26, VOLT_CAL, 1.7); // voltage (pin analóg, calib, fase change)
delay(500);
void loop() {
connect_wifi(); // verify wi-fi
connect_MQTT(); // verify MQTT
send_data_iot_platform(); // send data to TagoIO)
// Func init wi-fi
void init_wifi(void) {
delay(10);
Serial.println();
Serial.println("------ WI-FI -----");
Serial.print("Connecting to Wifi: ");
Serial.println(ssid_wifi);
connect_wifi();
// Func connect to wifi
void connect_wifi(void){
if (WiFi.status() == WL_CONNECTED)
return;
WiFi.begin(ssid_wifi, password_wifi);
while (WiFi.status() != WL_CONNECTED){
delay(3000);
Serial.print(".");
Serial.println();
Serial.print("Successful connection to Wifi network: ");
Serial.print("IP: ");
Serial.println(WiFi.localIP());
Serial.println("---------------");
// Func init MQTT
void init_MQTT(void) {
MQTT.setServer(broker_mqtt, broker_port);
// Func conect to MQTT
void connect_MQTT(void){
char mqtt_id_randomico[5] = {0};
while (!MQTT.connected()){
Serial.print("Connecting to MQTT: ");
Serial.println(broker_mqtt);
/* id mqtt random */
randomSeed(random(9999));
sprintf(mqtt_id_randomico, "%ld", random(9999));
if (MQTT.connect(mqtt_id_randomico, MQTT_USERNAME, MQTT_PASSWORD)){
Serial.println("Successful connection to MQTT");
Serial.println("----------");
else{
Serial.println("Failed to connect to MQTT...");
Serial.println("Retry in 5s...");
delay(5000);
// Func send data to TagoIO (MQTT)
void send_data_iot_platform(void){
temperature_read = dht.readTemperature();
humidity_read = dht.readHumidity();
emon5.calcVI(10,100);
voltage_read = emon5.Vrms;
//voltage_read = 127;
if((millis() - millis_Time) > 3000) {
Serial.print("Temp: ");
Serial.print(temperature_read,1);
Serial.print("°C;\t");
Serial.print("Humidity: ");
Serial.print(humidity_read,0);
Serial.print("%\t");
Serial.print("Voltage: ");
Serial.print(voltage_read,1);
Serial.println("V");
// send temperature
char temperature[250] = {0};
StaticJsonDocument <250> tago_json_temperature;
tago_json_temperature["variable"] = "temperature";
tago_json_temperature["unit"] = "C";
tago_json_temperature["value"] = temperature_read;
memset(temperature, 0, sizeof(temperature));
serializeJson(tago_json_temperature, temperature);
MQTT.publish(MQTT_PUB_TOPIC, temperature);
// send humidity
char humidity[250] = {0};
StaticJsonDocument <250> tago_json_humidity;
tago_json_humidity["variable"] = "humidity";
tago_json_humidity["unit"] = "%";
tago_json_humidity["value"] = humidity_read;
memset(humidity, 0, sizeof(humidity));
serializeJson(tago_json_humidity, humidity);
MQTT.publish(MQTT_PUB_TOPIC, humidity);
// send voltage
char voltage[250] = {0};
StaticJsonDocument <250> tago_json_voltage;
tago_json_voltage["variable"] = "voltage";
tago_json_voltage["unit"] = "V";
tago_json_voltage["value"] = voltage_read;
memset(voltage, 0, sizeof(voltage));
serializeJson(tago_json_voltage, voltage);
MQTT.publish(MQTT_PUB_TOPIC, voltage);
