Edit Tags for a Specific Device
In the following code I am creating a device from a form on blueprint devices with their corresponding labels. But now what I would like is to be able to edit that data from the device labels.
const { Analysis, Account, Utils, Device } = require(“@tago-io/sdk”);
if (!scope[0]) {
return context.log("The analysis must be triggered by a widget.");
context.log(“Creating your device”);
const env = Utils.envToJson(context.environment);
if (!env.account_token) return context.log(‘Missing “account_token” environment variable’);
else if (env.account_token.length !== 36) return context.log(‘Invalid “account_token” in the environment variable’);
const account = new Account({ token: env.account_token });
const dashboard_dev_token = await Utils.getTokenByName(account, scope[0].device);
const dashboard_device = new Device({ token: dashboard_dev_token });
const network_id = scope.find((x) => x.variable === “device_network”);
const connector_id = scope.find((x) => x.variable === “device_connector”);
const device_name = scope.find((x) => x.variable === “id_tienda”);
const nombre = scope.find((x) => x.variable === “nombre”);
const device_eui = scope.find((x) => x.variable === “id_tienda”);
const region = scope.find((x) => x.variable === “region”);
const zona = scope.find((x) => x.variable === “zona”);
const tamano = scope.find((x) => x.variable === “tamano”);
const status = scope.find((x) => x.variable === “status_operativo”);
const direccion = scope.find((x) => x.variable === “direccion”);
const email = scope.find((x) => x.variable === “email”);
const tienda_user = scope.find((x) => x.variable === “tienda_user”);
const solar_activa = scope.find((x) => x.variable === “solar_activa”);
const check_eolica = scope.find((x) => x.variable === “check_eolica”);
const entidad = scope.find((x) => x.variable === “entidad”);
const cp = scope.find((x) => x.variable === “cp”);
const gerente = scope.find((x) => x.variable === “gerente”);
const id_cont = scope.find((x) => x.variable === “id_cont”);
const carga = scope.find((x) => x.variable === “carga”);
const demanda = scope.find((x) => x.variable === “demanda”);
const no_medidor = scope.find((x) => x.variable === “no_medidor”);
const tarifa = scope.find((x) => x.variable === “tarifa”);
const multiplicador = scope.find((x) => x.variable === “multiplicador”);
const facturacion = scope.find((x) => x.variable === “facturacion”);
if (!connector_id || !connector_id.value) {
return context.log('Missing "device\_connector" in the data scope.');
} else if (!network_id || !network_id.value) {
return context.log('Missing "device\_network" in the data scope.');
} else if (!device_eui || !device_eui.value) {
return context.log('Missing "device\_eui" in the data scope.');
const result = await account.devices
.create({
  serie\_number: device\_eui.value,
  tags: \[
    { key: "CUENTA", value: "RETAIL" },
    { key: "TIENDA", value: nombre.value },
    { key: "device\_eui", value: device\_eui.value },
    { key: "REGION", value: region.value },
    { key: "ZONA", value: zona.value },
    { key: "TAMAÑO", value: tamano.value },
    { key: "ESTADO", value: status.value },
    { key: "DIRECCION", value: direccion.value },
    { key: "SOLAR", value: solar\_activa ? solar\_activa.value.toString() : '' },
    { key: "EOLICA", value: check\_eolica ? check\_eolica.value.toString() : '' },
  connector: connector\_id.value,
  network: network\_id.value,
  active: true,
  type: "mutable",
  chunk\_period: "month",
  chunk\_retention: 13,
.catch((error) \=> {
  dashboard\_device.sendData({ variable: "validation", value: \`Error when creating the device ${error}\`, metadata: { color: "red" } });
  throw error;
To access this feature, you’ll need to create a widget of the ‘Device List’ type. You can find step-by-step instructions on how to do this in the following tutorial:
Tutorial on Creating a Device List Widget.
