I’m making an application and I would like to download and save the bucket data as .CSV.
I’m currently using analize to generate the .CSV and save in the Files, but I haven’t found any function that allows me to download the .CSV to the machine.
Is there any way that allows me to generate this download?
To download a file in TagoIO, you can follow these steps:
- Navigate to the files section in your TagoIO account.
- Choose the file you want to download and click on it to open the file details.
- Copy the File URL from the file details page.
If you want to create a download link using a widget, you should create a variable in your bucket with the following JSON body:
"variable": "list_download",
"value": "Download CSV",
"metadata": {
"url": "https://url-download-from-file.com"
Replace “https://url-download-from-file.com” with the actual URL of the file you want to download.
Now, you can select this variable to display in your table. This allows you to create a download link for your file within a TagoIO widget.
For more information on how each field in the metadata works, you can refer to the documentation here: Widget Metadata Field List.
Thanks, I applied this solution and it worked fine
