Display variable on map
I’ve mapped some non-GPS LoRa temperature sensors using the Device > More > Quick Map feature. However, the only way the points will display correctly on the dashboard map is to select the “location” variable for each device when adding to the map. If you try to select any other variable the point will not appear on the map. Also, the lat/lon displays in the text callout for each point. What I would like to do is show the temperature variable in the text callout since showing lat/lon for each point on a map is not necessary. It is not possible to display a second variable. Is this a bug or am I missing something? thanks
@Fabiano Eger
hi @treebert,
We have another topic with the same question. Please check out this topic: Non-location variables in the Infobox of the Map widget (new Normal Dashboard) - #3 by devel
