I’m using the Device List Widget to display and edit device parameters. In this Blueprint dashboard I am filtering by device ID so that the parameters for just one device are shown. To my knowledge, this is the only mechanism for a user to edit device parameters with the standard (non-custom) widgets - correct me if I’m wrong here.
Is there a way to hide the pagination controls at the bottom of the widget? They’re not needed when I only have a single row of data and would make for a more compact display.
Hi zsu[@user:10052104078]zsu,
You are absolutely right that the Device List Widget is indeed the primary standard (non-custom) widget mechanism for editing device parameters, including tags and configuration parameters.
Unfortunately, there is currently no built-in functionality to hide the pagination controls in the Device List Widget. These controls are a fixed UI element of the widget, regardless of the number of rows being displayed.
However, I encourage you to suggest this as an idea to be implemented in TagoIO for the ability to hide pagination controls when they’re not needed.
