Hi everyone, I have created a custom tag for all devices with the EUI of that device. The idea was to have it show on the dashboard so that when a device was being moved or renamed, you could be certain that you are moving the correct one by looking at the eui on the actual device. I created a device list table, and the EUI is selectable. Shows perfectly on the windows dashboard, but “no data available” on the phone. Any ideas?
Here is a screenshot of the dashboard on the computer…
In order to trying to replicate the issue, I would need for you to provide the app version and the operational system of your mobile. Please send that to me and I will take a look.
app version TagoRun 1.5.1
app version Tagoio 5.1.2 (also doesn’t display)
Iphone 12 Pro, software version 15.1.1
Web interface on iphone does display correctly, as it does on computer.
Web interface on iphone works. Ok. Where exactly is showing “no data available”? Are you trying to access through TagoIO app and its not displaying the devices on the device list widget?
Did you make sure the user you’re logged in on your RUN end has correctly Access permission for that device? If not, it wont appear. (That may be why its appearing on admin and not on RUN)
This is an example of full access, you can try implement it and see if the device is appearing for you on the RUN end.
OK, still not working as expected, I created a new tab called Edit Device, added two Device Info tables with Name/EUI and a parameter with the ability to edit (not the eui of course).
On the mobile, nothing shows, even after a refresh/log out and back in…
Also one of the Device info tables which I moved from the first tab to the third, didn’t seem to move, just shows an empty square where it was removed from with the usual “waiting” circle…
