gadotti
(Iaran Gadotti)
November 11, 2023, 4:57pm
1
Dear Srs.,
the fill color under configured conditions is not working. It assumes the color of the wrong condition range.
Please, see the pictures, with the given value it should be blue.
Am I doing something wrong?
Other point, I would like to have a different quantity of tick marks, in order to avoid the non integer division marks. Is it possible to adjust a custom quantity?
Thank you
Hi Iaran!
I suggest you change the order of your conditions
Like this:
Hope this helps!
gadotti
(Iaran Gadotti)
November 15, 2023, 1:52am
3
Hi Freddy,
I changed the order and still the same problem.
There must be something wrong… it is a simple configuration.
I tested the limit values with comma and dot, no difference.
Please, can you check what could be the reason?
Reagarding the second question (a different quantity of tick marks), did you find something?
Thank you
Thank you.
gadotti
(Iaran Gadotti)
November 16, 2023, 9:10pm
4
Hi Freddy , did you find something about this issue?
In case I decide to implement a custom widget, similar to this tank, do you have any code example to share? I could use as a reference…
Thanks,
Iaran
Hi Iaran,
I checked it here and it worked as expected in all 3 conditions.
Are you sending the color metadata key in the variable?
That can override the color options you setup.
As for the tick marks you can chose between the 5 options here (They will all end up having decimal ticks since they are multiples of 5):
I’m sorry but I do not have a code example for a custom cylinder widget.
