The Custom Widget SDK now has a React package. The new @tago-io/custom-widget-react gives you a hooks-based API for building dashboard widgets — real-time data, CRUD operations, widget config, all accessible through hooks.
npm install @tago-io/custom-widget-react
Requires React 18+. Full TypeScript support included.
How it works
Wrap your app in <TagoIOProvider>. After that, every hook has access to the widget context — no manual listener setup, no postMessage wiring.
import { createRoot } from "react-dom/client";
import { TagoIOProvider, useRealtimeData, useWidget } from "@tago-io/custom-widget-react";
function WidgetContent() {
const { label, loading } = useWidget();
const { data, eventCount } = useRealtimeData();
if (loading) {
return <p>Loading...</p>;
return (
<div>
<h3>{label}</h3>
<p>{data.length} records — {eventCount} updates received</p>
</div>
createRoot(document.getElementById("root")!).render(
<TagoIOProvider>
<WidgetContent />
</TagoIOProvider>
The hooks
14 hooks covering the full widget lifecycle:
useRealtimeData()— Subscribe to live device data. Supports three strategies for incoming records: replace, append, or merge.useSendData(),useEditData(),useDeleteData()— CRUD operations on device data. Loading and error states come back from the hook directly.useWidget()— Widget config, variables, and dashboard context.useUserInformation()— Current language, timezone, token, and user preferences.useBlueprintDevices()— Blueprint device selections and settings.
Re-renders
The SDK uses selective subscriptions — components only re-render when the specific data they consume changes. The merge strategy applies structural sharing, so unchanged records keep their references. If you’ve dealt with unnecessary re-renders from context providers before, this is specifically designed to avoid that.
Vanilla JS still works
The vanilla SDK (@tago-io/custom-widget) is at v2.0.1 and fully supported. Existing widgets don’t need to change.
Check the examples in the repo for read-data, send-data, and resource-access patterns.
