I am having some trouble creating a new device through a dashboard. I’ve created the Analysis script, however when it runs using my Input Form the Analysis Console says “Invalid Connector”
[2021-10-18 21:02:03] (node:2686) UnhandledPromiseRejectionWarning: Invalid connector (Use node --trace-warnings ... to show where the warning was created)
I suspect I need to set something different in my Field Options, but I’m not quite sure what to set.
Do I have to configure Custom Connectors and Networks for this to work properly?
Basically I’m trying to get it so an end-user can open up the Blueprint Dashboard, click “Add Device”, fill out the form and quickly be viewing their device data on my dashboard.
Any help would be appreciated! Thank you very much!
So that leads to my next question… how do I find the value for connector id / network id on Tago? I’m trying to add my Dragino LHT65 which is on Helium. The value is specific to TagoIO correct?
And I’m using the ‘create device using dashboard’ script Tago provided.
