Hello, I would like to know if it is possible to check whether a parameter is read or not with a widget. The idea is to know if the device was able to read the defined parameter, and show on the dashboard that it was updated on the device.
Hi zsu[@user:10092607716]zsu
That information is not available through TagoIO widgets. It is possible to access it with Custom Widget, as the widget does receive the full object of the configuration parameter, but the standard widgets currently doesn’t include any setting to access the “read” information.
We are going to keep that in mind for future updates!
